1 - 8 of 8 Posts
The perches are for YJ springs. The rear set is the same as the front set. So I need to grind my perch on one side. Ok what about the u-bolt. Should I buy a larger set for the front. And make it fit(BFH).
Also, for the front end what brackets should I go with Cj7 or Yj. I'm not going to fab up the front Pev-Brackets. I would like to buy a set. My Prob is which one will fit my Frame (CJ7 or YJ).
Thnx
i used square tubeing for my perches on my narrow track 30, SOA with wrangler springs. i had to grind the housing minimully for the u-bolts. i was able to do this by cutting open the perch to fit over the houseing. i then had to grind enough to fit a 3.5" u-bolt (i think) over the housing. worked out fine.
1 - 8 of 8 Posts
