1 - 6 of 6 Posts
Kevin, the main relay is in the driver's side kick panel, the circuit opening relay is in the passenger kick panel above the ECU. No start TS chart says to check:
  • Ignition spark
  • Timing
  • Fuel supply to injectors, Should feel fuel pressure at cold start injector, should indicate voltage at FP (Upper right terminal) of circuit opening relay during cranking and running
  • Check fuel pump switch in AFM, should have continuity between Fc and E1, left connection and one next to it.
1 - 6 of 6 Posts
