1 - 4 of 4 Posts
I’ve got the 22RE and the dana300. What years of AW4 do I need to get. Some of my ready shows different spline counts. If someone could help me out I’d like to do a little scavenging this weekend.
Discussion Starter #2
Ok found my answer on Novak’s site.
21 spline shafts are for:
AX4 & AX5
AW4, typ. 1987-1990
23 spline, extended length shafts are for:
TF904/909
TF999/32RH
NV3550
NSG370
No additional input shaft is typically required for:
AX15, 1988-1999
AW4, 1991-1999
My AW4 came from a Grand Cherokee when I did my swap. Iirc it was a 98. If you search Timber Tiger for my build in gen 4x4 you will see the specifics that I dealt with.
I had to purchase a adapter ring from Advanced Adapters to mate my Atlas behind my AW4. Apparently some but not all AW4 castings require this. I lucked out and ended up with the oddball one.
https://www.pirate4x4.com/forum/general-4x4-discussion/1902329-timber-tiger.html
When I did my 300 swap in my Cherokee behind an AW4 you have to use a 3/4” spacer ring or machine the bearing retainer snout on the 300, mine was also a flip ring as well to get it to driver drop.
1 - 4 of 4 Posts
