1 - 8 of 8 Posts
I bought a half finished Samurai and am now working on completing the build and need some help. My Sami has a 4.3 L vortec mated to a TH400 to a Dana 20. For those of you who have done this before, can you share with the radiator you used. Also, the stock exhaust manifold flanges end right at the framerails. I was thinking of finding a set of block huggers to solve this problem. Will this work? I am not a tremendously experienced builder so any help would be appreciated. Also, I welcome advcie on any "gotchas" that you have experienced. I have to have this thing ready by hunting season and I have a lot of work ahead of me.
Thanks
troy
i had one with a 3.8 about the same thing i took the driver side manifold and put it on the pass that worked for me try this place http://www.suzukiconversion.com/
This is the radiator I will be using for my 4.3 swap. I havent started the swap yet, but I do already have the radiator. I read that its the radiator a lot of guys are using in there samurais.
67 Ford Mustang.
http://store.summitracing.com/partd...908331+4294925084+4294840071+115&autoview=sku
I also have these headers. Also is what I read that most guys are using.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=HED-69400&N=700+115&autoview=sku
I have not yet started my swap, I'm still gattering parts and info.
These are the hedders I used and they fit good. I put my engine higher than normal so they almost touched the frame but with the engine sitting slightly lower it shouldnt be a problem. I had to knotch the pass floor a inch or two to dodge the hedder.
I bought my radiator from rock4xfab and I love it. A custom aluminum radiator shipped for about 200 was a great price. I even opted for the larger one and I made it fit under the hood. Give scott a call and tell him you are doing a 4.3 and he will hook you up.
My sammi has a 4.3L-th350-toy tcase.
I'm using a radiator from speedway motors 19" X 22" chevy aluminum. (think I paid $120)
exhaust manifolds...I used stock '95 manifolds and run side pipes.
Here is a couple older pics on how I routed the exaust
my 4.3 is sitting lower than yours (manifolds rattle against the frame when running) and my tub doesn't sit near that low. did you cut the transmission tunnel to get it to set that low? I just finished tearing mine back down over the weekend so I can figure out a better way to set my motor/trans/tc back in so my tub can be flush on the frame.
1 - 8 of 8 Posts
