1 - 5 of 5 Posts
Okay here is the problem I have, Up untill the fire I had I've had a little hi-speed miss. Now that I have replaced most of my vaccuum hoses and fixed the little bit of wires that were burnt the miss is more noticeable now, and it's annoying. Tommorow I plan on changing the plugs incase it's that. But today after wheeling it a little the miss was bad like it was loading up on fuel, It seems wierd that it is loading up since it's fuel injected. Also sometime it seams like it's going to stall but if you give the accelorator a shot it's fine.
I'll check the egr out after i do the tune up tommorrow. I need to pull the distibutor to get a screw out of it that broke off the cap.
1 - 5 of 5 Posts
