1 - 2 of 2 Posts
I am going to bypass all of the rear window wiring and run the window directly from the switch in the console (86 4rnr). There are 5 wires on the switch and for the life of me I can not figure them out, any one got any schematics? <IMG SRC="smilies/bounce.gif" border="0"> <IMG SRC="smilies/bounce2.gif" border="0"> <IMG SRC="smilies/massey.gif" border="0">
2 are for the light in the switch, 1 is the ground wire that gets switched to the 2 up/down wires. With a multi-meter, you can figure out which is which pretty easily.
You may want/need to run the motor power through a relay setup instead of straight through the switch. Actually, you pretty much *have* to if you want to use that switch...
1 - 2 of 2 Posts
