1 - 20 of 29 Posts
Looks like an actuator off an old "C" band satellite dish
Not a bad idea at all
Discussion Starter #3
Googled "trailer jack" and I see some that are similar, 15" travel etc.. Pretty neat idea.
looks like that would be sweet to automate. JGSTURBO where you at. MOunt a damn servo drive on there, some sort of rotation encoder and rig it up where you put in a bend angle and it just goes...Way easier than hydro
That he got it from a junkyard for $8 makes it worth it. But looking at some of the prices for new I'd probably be looking at a ball screw to fabricate my own setup.
^^^ This. Or next SWAG offering perhaps?
I like the manual trailer jack in a high LB rating....
Should be pretty easy to use it as is or take the handle off and put a servo drive of some sort on there and make it accurate.
Tubing Junky
I'm not thinking a 1000lbs is enough. The HF jack is 8ton? And it seems to be just enough to bend at a decent speed.
Somewhere on minibuggy.net I remember an RV jack bender...
Slow enough lead screw and the pipe threader I can see this happening.
As far as servos or stepper motors, anything can be relay controlled with an encoder tube angle finder. One needs on that reads the stock as floating zero point then tracks on the tube in the shoe.
Looks they will make a jack in any spec Contact Us at Atwood Mobile
They have up to 20K stuff.
Wonder what the max OD on the jack could be and what the minimum travel needs to be. I dont have anything here to measure off of.
also I am seeing lots with built in gear drives. Would be perfect. Not super fast depending on power source but being slow, it would be accurate.
thought I'd bring this back up with an update. I put a trailer jack on my Jd2 bender, it works nicely! It bent some .120 wall 1.75" HREW using a cordless hand drill, one handed :D
Vendor
Now that is pretty dang slick. Mount up yourself some sort of permenant drill/pipe threader, and one of the harbor freight momentary foot switches, and you have an awesome quiet, electric hands free setup. Not having to deal with the hydraulics is pretty appealing!
1 - 20 of 29 Posts
