1 - 20 of 28 Posts
Ok, this idiot to remain nameless to protect myslef.... I mean them, let his Dana 44 w/456 gears and and ARB burn up due to lack of lub. while motoring down the interstate. Pulled the rear drive line, added oil.. Yes I, ahhhh.... I mean... they... do have a SYE so no problem with loosing T case lube. From there proceded to limp in 4 high toward home.
First place I,, ahhh they... stoped they by miracle pulled up next to a gentalman in a monkey suite... grease monkey that is, that had a chevy dealers patch on it. He was just sitting there in his car.. what luck! Asked him if it would be ok to limp home on front axil. He said take it easy and it will be fine he's done it himself.
so questions are:
Take it easy? what is that?
A. dont do the Rubicon tommorow
B. Follow speed limit signs
c. Do 55 on the interstate posted at 65
D. Do 35 on same interstate and only shoot every third person that honks at u.
E. Get off the damn Interstate and do 15
How long can I.... ah... they.. drive around on front axil with out damage to front axil or more damage to the rear if taking it easy? ... see above.
A. Park it and ride bicycle in the rain and snow
B. New conversion to front wheel drive.. drive it accordingly
c. as long as u want, just dont go 4wheeling
What should I.. ahhh mean my friend..... expect to have to do with his rear end... THE DANA!... besides replace all bearings
A. Rob a bank and replace everything including axil shafts
B. Replace ARB, Ring and Pinion (pinion can be rattled with a firm handshake from the U joint end)
c. replace spiders in ARB
D. ?
Ok.... let me... ahhh them have it now. <IMG SRC="smilies/rolleyes.gif" border="0">
Did I mention I'm broke! till my condo sells. <IMG SRC="smilies/crybaby2.gif" border="0">
[ 10-14-2001: Message edited by: coachgeo3 ]
Discussion Starter · #2 ·
Need Help!!!!!! and a gun to shoot myself.. I mean my friend <IMG SRC="smilies/rasta.gif" border="0">
my friend 'james93YJ' drove his around for over a week in front wheel drive (with the fluid dribbling out of the TC) and didn't have any problems...I don't know what you, ahh, I mean your friend... might need to replace in the diff, bearings of course, but the ring and pinion might be okay. They're pretty tuff!
Originally posted by Cutter:
<STRONG>my friend 'james93YJ' drove his around for over a week.......</STRONG>
TY Responder #1 you get the prize behind door number One... (busted axil parts) serously.. thanks for responding
NEXTTTTTT responder please Need all the advice I can get.
There's really no way to tell once the diff cover is taken off to see what damage has been done. If the gears are shot then there will be visible wear and grooves on the pinion itself. All bearings should be replaced as well as the seals. If there is that much play in the pinion just from yanking the driveshaft around the seals are most likely shot. Replace all to be on the safe side. I personally don't know much about the workings of ARBs so I can't help there. The only way to tell the extent of the damage is by getting a firsthand look from taking the diff cover off. One thing to look for is metal shavings at the bottom of the diff. If there's alot of metal shavings then you are most likely S.O.L. Anyone else have anything to add?
Originally posted by BabyWrangle:
<STRONG>There's really no way to tell till the diff cover is taken off to see what damage has been done...... Anyone else have anything to add?</STRONG>
Ty respnder number two. You get whats behind door number 2. (used 90 weight gear oil with nice shiny flakes of stuff in it) But seriously... I do thank you... and agree about removing cover, but its raining out side right now, and Im not sure all what to look for yet.
LIke he said... anyone got anything else to add <IMG SRC="smilies/question.gif" border="0">
I tweaked the diff cover on a AMC 20 - Got on the hiway after wheeling - Mine locked up, tight. Twisted the rear shft into - AAA hauled mine home. Every thing except the housing was toast. Hope you have better luck. <IMG SRC="smilies/smokin.gif" border="0">
Discussion Starter · #9 ·
Originally posted by Merlin:
<STRONG>I tweaked the diff cover on a AMC 20 - Got on the hiway after wheeling - Mine locked up, tight. Twisted the rear shft into - AAA hauled mine home. Every thing except the housing was toast. Hope you have better luck. <IMG SRC="smilies/smokin.gif" border="0"></STRONG>
I ahh.. they, did not lock up... just felt something go and the smell of oil. Rolled off the road.. Worry mostly about the ARB!!!
Driving around in front wheel drive is no big deal, Know people who have done it for weaks at a time even with v-8 and 35's. As far as the rear end new bearings and seals and new gears if there is evidance of bad wear. If the pinion gear is real loose you may want to take it out so it doesnt get bound up and lock the rear end while driving in front wheel drive.
Discussion Starter · #11 ·
well is no news good news? no one has said anything about the ARB!
What would have went out? the spiders?
i did the same thing with my 44 only i got it towed home
after removing the diff cover i noticed that the pinion shaft could be moved by hand not a good thing
closed it back up let it sit for 2 weeks while i talked myself into doing the repares
the hardest part of the whole job was removing the pinion nut
o bought the master install kit put new bearings and races through out and it was not that hard to do
took me most of the day to do it but i would not think it woould take half as long now that i have done it
give it a shot it is all ready fawked up so you have nothing to lose but the cost of bearings races and seals
Discussion Starter · #13 ·
Originally posted by Chris H:
<STRONG>i did the same thing with my 44 only i got it towed home
o bought the master install kit put new bearings and races through out.... </STRONG>
sure would be nice if this is how it turns out. But would it be simular or lot more complicated since I got an ARB.
Gear heads out there help me calm my confusion? If it is bearing and races replace issue only... then what gives out or slips thus causing the loosing, or partially loosing, of rear wheel drive?
i can't help with the arb problem
and you won't know till you take it apart
remember keep the bearing caps apart so you know which side they came off of
keep the shims seperated so you know where they go
it is not really that hard of a job
mine was jerking around and what it was was the loose pinion from trashed bearings was letting it bind up
all of my bearings fell apart in my hands they were that bad
but new bearings and race and all is better no wine no slop and no metal shavings in the gear oil i have changed it twicw and run a magnet thru the lube looking for metal
all is good
if you have any questions email me at
[email protected]
Discussion Starter · #15 ·
<STRONG>i can't help with the arb problem
mine was jerking........ </STRONG>
Thanks I may just call on ya after my two weeks har har
cept I got to drive it!!!!
Discussion Starter · #17 ·
Originally posted by CJ-Jeeper:
<STRONG>It happened to me in a model 20. The ARB was ok</STRONG>
shittt..... u blew it!... "no news is good news"... now since u say it came out ok for you, then I'm going to be jinxed....
J/kiddn... hope its the same fer me! What did u have to do to repair ur differential?
coachgeo3- Tough break...would like to know how the fluid got that low. Nobody would ever forget to add fluid when doing a service change? Anyways, if I was a diff and had no oil in me, I would turn my pinion bearings blue and my seal would be melted. 60 dollars?
Discussion Starter · #19 ·
Originally posted by ZUK:
<STRONG>coachgeo3- Tough break...would like to know how the fluid got that low. Nobody would ever forget to add fluid when doing a service change? Anyways, if I was a diff and had no oil in me, I would turn my pinion bearings blue and my seal would be melted. 60 dollars?</STRONG>
Service done 4 weeks ago prior to my across country drive.. new fresh oil everywhere. What did me... ahhh.... them in was a known trany fluid leak masking what I am guessing to be an unknown rear end seal leak. Symptoms were there and did not read them properly.
do I have to remove gears and arb from the carrier to change all the bearings and seals? Like do I have to reset all the gears which I have no knowldege on how to do? Are any of the seals or bearings pressed in? Do I need any special tools? I have cheap air tools and sockets but no press or other speicial tools. Also my garage too short. I cant jack up the jeep. only 1/2 inch between the jeeps rack and the rafters.
seems like it would be a real hassle not being able to jack up the gas tank to make access easier to the diff cover....the arb case itself is probably in there really tight and would cause you to cuss big time trying to wedgey it out with tire irons and such.....the pinion nut is not a real issue as long as you have the right socket(1 1/8" I think) and a long plumbers wrench to secure the yoke from turning. let us know what you do and what you find. ZUK
.ps---nothing would need to be re-set with a little luck...it is a d44....does not use a crush sleeve....has a solid collar design with an associated shim pack...should be able to re-use the shim on the pinion that set pinion depth and pinion preload. With the pinion in hand you may want to have a shop press off the one troublesome pinion bearing and press the new one one with the same shimpack. Then put the pinion back in the housing, tighten the nut as tight as you can(about 200 foot/pounds) and spin the yoke to see if it feels good. Not tight and not wobbly.
[ 10-15-2001: Message edited by: ZUK ]
1 - 20 of 28 Posts
