1 - 20 of 65 Posts
Well,after setting in my garage for almost 7 months. Looks like I will be home long enough to start the build. This rig will not be built over night, I am still
gathering parts. I have most of the big parts here. Hendrix X chassis, 2002 4.3L chevy V6, th350 w/K case, Dana 300 w/4:1 twin stick,with Toyota axles
Ridding on saw-a-way 2.0 air shocks. Still Have not decided on a tire looking for something in a 37".Also got 2 highback prp seats and 1 36" prp bench for the rear
Discussion Starter · #9 ·
working on getting the motor and trans set. I got it back and as low as I thank it should be? Question is should the trans pan be level,and should I worry about only having a 1/4" gap between the pan and the link mount .
Discussion Starter · #10 ·
Parts I am waiting on are Assembled upper and lower links from Hendrix
AA Adapter TH 350 to Dana 300 from Rock Buggy Supply
And a clocking ring from Desert CJ
Parts I recived latly Bushings from poly performance
Cool as hell Diff covers and battery box from BTF
What power steering pump and alternator do you plan to use?
This is almost the same setup I'm putting in my buggy right now.
I would also be worried about the pan hitting the link mount as the drivetrain torques over unless you're planning to rigid mount the entire drivetrain.
1 - 20 of 65 Posts
