moto261 said:hay :flipoff2: dont you think you should use the PM's for this all the hard core people mite get there Panties in a bunch
:massey:
scO44 said:USE THE SEARCH DAMIT!!!!
Shrock said:PBB g-strings now on special in the vendor forum. :flipoff2:
Rockrat said:
AND YOUR POINTrollerskate said:
HEY!!! I tried those links,they don't work!!!???![]()
Rockrat said:
AND YOUR POINT
Well then now that, its cleared up:flipoff2:DSI said:
the point was you suck :flipoff2:
And we give the newb's a hard time for padding,godzuki said:fawkit then:flipoff2: :flipoff2:
just shows the rise in boardum, On the lines of tech im producing flange adapters to adapt toy shafts to early model zuk cases![]()
Benefit of adapting any toy drive shaft be it 82-85 to any small flange zuk t-case/rear pinion. its not generally a problem when you have the larg flange. 84 toy shafts have the same hole pattern as the the large zuk flange, all you need is a spacer but if you got the small zuk case your lefted searching and fabbing, I have all the drawings dimensions, and PATENT on this new adapter, have to fund the project some how it s more for the guys that dont want to change out there axles and spend $65.00 at suzuki for the large flange but still want the beefier shaft.DSI said:
and what would the benifit of this be?
c'mon if u're gonna post tech at lest explain it! and give us all the spec's so we can copy it :flipoff2:
Rockrat, How much$$$ are the adaptors going to be???? And when are you going to start producing them?Rockrat said:
