1 - 10 of 10 Posts
Last weekend I was wheeling with some friends and one of them blew a bead and we needed two hi lifts, one to stabilize his rig on one side and the other to lift the tire up so we could put air in it. I saw the most amazing thing. A hi lift jack that worked. He keeps his inside attached to the roll bar , mine is attached to the rear bumper. Needless to say mine was hard to get started and hard to get it to lower. When he used his it was effortless. When I got home I hosed mine off and tonight I spayed some silicon spray on it. I always thought the hi lift was just always hard to use since everyone I’ve ever seen use one struggled with it. But after cleaning and lubing my hi lift, it works great.:)
Now I know. Keep the hi lift clean and it will save you headaches on the trail.
Banned
Mine was hard to use when I first got it because they laid the powdercoat on a little too thick, the pin wasn't sliding into the slots easily enough. Enough work on it and it works fine now. I WD40 it on occasion but i haven't needed it much.
we used wesson oil once.
1 - 10 of 10 Posts
