1 - 3 of 3 Posts
Any gains to be had from one(I think pertronix's makes one) on a stock electonic ignition set up on a stock 2f.
No performance gain. The basic reason is that a higher voltage spark doesn't produce any more power than a lower intensity spark because all the net energy released is in the air/fuel charge and all you need to do is initiate combustion to release all of it. Even if you have a "high energy" system doesn't mean that the running spark voltage will be any higher. The spark gap, compression and the air/fuel charge determine the spark voltage.
The way it works is that if you have a high compression, super/turbo charged engine, then you will need an ignition that is capable of producing a higher voltage in order to ignite the fuel. Most stock engines don't need a high voltage ignition.
thanks, thats was what kinda expected/thought/remembered ;)
John
1 - 3 of 3 Posts
