These require the use of rod ends, not TRE's.Originally posted by Rockbuggy:
<STRONG>Avalanche has great deals on there arms. I believe there $65.00 each. check out there site for details.
Avalanche Engineering
[ 08-29-2001: Message edited by: Rockbuggy ]</STRONG>
Sure go ahead I don’t mind. Here to help. The holes I got for $10 at a machine shop and he also made the tapered busing lock washer. $3.93 for grade 15 bolts locks washer and nuts and $8 for the knuckle getting machined flat. It was never intended for that arm. Non flat top. You don’t have this problem. I had Ford 44’s which need to be machined. It was easy all I did was make the measurements templates and do the finishing touches whit an angle grinder. I have bent the tie rod two times already and the arm never even flinched. I got the idea from Water Dog. It was his Idea I just made some changes for my needs. Its beefy and locks great and I can say (yup I made that too). <IMG SRC="smilies/grinpimp.gif" border="0">Originally posted by ozarkjeep:
<STRONG>CJ5, the reamer to make those holes costs damn near as much as one arm from parts Mike.
Hey Qbert, do you care to answer a few dumbass questions via Email?</STRONG>
