just to clarify this for the others, its a 8.8 ring gear in a 9"...KWTMECH said:Their 9'' hi pinion is actually an 8.8
Flipping a 9" is not a good idea unless you want to go really fast in reverse.mtnbronco said:The flipping of the 9" is not a good idea for the rear axle. You would be running on the back side of the gear.... What we need is some to offer reverse cut gears for the 9" then we can flip it... But until then use a HP 44 or if you have the money the Tera 60
Just my 2 cents
putting the motor out back helps!mudtruck44 said:
Flipping a 9" is not a good idea unless you want to go really fast in reverse.Reverse cut gears won't make it spin the right direction either.
I'll disagree with you. You can run a HP9 with a 6 cylinder if you stay with a 35" or smaller tire.mtnbronco said:I would recommend to stay away from the currie HP 9". its a 8.8 ring gear in a 9" case. they only rate it up to 400 Horse. That means it was designed for the 4 cylinder jeep engine stuff. The flipping of the 9" is not a good idea for the rear axle. You would be running on the back side of the gear.... What we need is some to offer reverse cut gears for the 9" then we can flip it... But until then use a HP 44 or if you have the money the Tera 60
Just my 2 cents
