1 - 20 of 33 Posts
OK, I am selling my rear axle. This is set up for Clayton's 4 link rear suspension and has his high clearence bracket kit on it as well as an ATV winch mount. Has an ARB and 513 gears in it now, but I also have 456's that were in it before. I have a Super 88 kit in it now, one axle shaft has a little bend in the flange, but I have another brand new Super 88 kit. So you would have brand new axles and a full set of spares. Dave Kemner from Full Circle Shaved this long ago, this and the brackets allow it to slide over everything and has the same ground clearence as a d35 but is WAY stronger. It can be set up for 5x5.5" or 5x4.5".
It will have no brakes, so you will need to get some out of a junk yard...easy and cheap to do. Also, the shock mounts are custom, so you may need to change them. If this is a problem just pm me and I can work something out that is stockish.
Here is a basic parts list:
Base axle - $100-$200
ARB - $800
513 and 456 gear set - $200 each
Clayton high clearence bracket kit - $270
Super 88 kit - $600
Spare Super 88 kit - $600
Shave axle - $300-$400
Diff cover - #100
Plus all the labor to weld it all together and set up the gears if you can run the 513's.
You are looking at over $3000 easy for the parts alone.
im located near hershey pa, asking 1750 for the axle i can get pic's pm or call if interested 717-673-7303
Discussion Starter · #19 ·
yes i will sell the super 88 id really like to sell as complete axle but pm me with what u want and yur offer member the super 88's have lifetime warranty
1 - 20 of 33 Posts
