Ok, so alot of people dont like the holley projection, but I have had only good luck with these systems, and I feel that alot of people's problems stem from not understanding how they work, and how to fit them to there application, so with that in mind, why would this unit not work on an M180, and or, is there a better solution.
http://www.holley.com/HiOctn/ProdLine/Products/FMS/FMSFI/501-12.html
I cant find pricing on this unit, but I would think it is cheaper than the 2dbl's I have bought in the past.
So, flame away guys.
Application
258 CID, M/T, Carter BBD 2 barrel carburetor
Features
A complete "stand-alone " system
Polished die cast aluminum throttle body
New digital ECU software is much improved over old analog system
Digital ECU is user-adjustable for:
......Idle
......Accelerator pump
......Main system
......High RPM
......Choke
Single 90 pph injector provides for all fuel requirements
Wiring harnesses are assembled with high quality connectors to provide for "plug-in " installation and protection from the elements
Fast idle solenoid is included
Uses factory air cleaner assembly
Installed height is no taller than stock Carter 2-barrel carburetor
Closed loop kit (P/N 534-54) is available for non-air-pump-equipped vehicles to further enhance driveability at all altitudes
Application
Features
......Idle
......Main system
......High RPM
......Choke
