1 - 20 of 1000 Posts
Tim84K10 said:
How much did it cost to make, total? How much time? Material?
Interested in selling copies of the plans?
x2!
That bender looks great! What size bolts did you use 1/2", 5/8", etc.? What size cross pins did you use?
I'm insterested as well. How much did you pay for the plans? If you don't want to sell them yourself, what seller lists those plans?
Thats cool. Very simple and looke effective. On that hoist jack you use they sell air powered ones for about $180 at northern tool.
I just bought those plans off ebay. Looks great good job!
What size die did you buy? What degree die did you buy? 120* 180* 240*?
That is going to be my next project
If you would like to find them, just search ebay for tube bender. It is the heaver duty one listed.
If you can't find it. You can look here. tube bender
clone
Goat, what did you use or how much did it cost to get the arms cut out?
is it hydraulic or did you fab the leverage mech also? if hydraulic what did you spend on ram, pump, hoses, valves....ect
thanks
The JD2 and Pro-Tools style only has to be bolted to the floor if you are using it manualy, if its hydro it doesnt need to be bolted to the floor...
[QUOTE='62FJ40]Goat, what did you use or how much did it cost to get the arms cut out?
thanks[/QUOTE]
I cut the arms out myself with a buddy, two benders were made. We did it using a gas hatchet, pedestal grinder and mill. It took about 18 man-hours, start to finish. So the total cost was $40 in surplus steel.
In the beginning I used the ratchet setup...but now it is manual hydro. The cylinder is something I got from gf's dad...it is hard to describe but imagine a 48" hydraulic hi-Lift jack. I'll try to find a pic.
I posted the arm plans a long time ago with the spacers and everything...do a search in Gen4x4 with my user name.
Super Moderator
'82 Scrambler, '14 Rzr
Are there any downsides to having it mounted that direction? It sure seems easier to get a long section of tube to rest vertical than it does when you are trying to get a long section to stay in plane mounted the regular way...
ditto, and how much were the plans? I like it! I got a bunch of spare reciever tube around too...
EDIT - bout $20 for the plans
1988 samurai & 2010 Ambulance RV - both 4wd
gents,
I just got my plans from www.gottrikes.com. They look first rate and very nice engineering job.
I've been looking for a bender to buy/build for a while now. Here's the reason I like this design the most:
1. not a "manual" bender. No bolting to the floor, or the room that it takes.
2. vertical design. with a pair of electronic levels, getting identical bends should be a snap.
3. uses common dies. Protools 105. any size up to 2." dia x .134" thick
4. portable - I'm adding wheels to mine so I can roll it anywhere!
5. $20 for a set of plans is a bargain!
The only down side (not for me) is you need a milling machine, fab skills, and welding skills. Or "friends with skills"
later,
Reflexx :D
Brandon said:
milling machine? What needs to be "milled" ?
Looks like just holes drilled (I got a drill press) and welding (I got a welder)
So you know your holes are DNO, not just close enough....:D
Brandon,
I only said milling machine because some of the holes are near an edge and might drift. A drill press will work just fine, just make sure you use a center-drill and gradually step up the drill sizes.
I'm gonna bore the holes :D 'cuz I can.
REFLEXX
