1 - 8 of 8 Posts
Ok, just pondering this thought and looking for pointers....
I found a brand new ram-cylinder at a garage sale that appears to be very similar to those used in the Rock Ram steering...Could I get by so easy by installing the ram down below on the linkage, and plumbing the two lines into the existing power steering lines of my stock power steering to assist the ram? Or is a new power steering box needed as the Rock Ram kits calls for...If this could work I would be looking total cost of around $100....Much cheaper then the Rock Ram! Thanks, Johnny
i dont have any experience with them but it seems to me that in the kits they would have to be valved in such away to insure they always move exactly the same otherwise it would damage the box or linkage. why not just ditch the box and go fully hydraulic? unless you drive on the street alot in which case im sure that would be a bad thing
You need to tap the box in the two areas of pressure access for each direction of travel. Route lines from here to the cylinder. Problem with a stock Toy pump and power steering box is there really isn't enough pressure/volume to drive both the box and the cylinder well. Most aftermarket kits include a mod'ed pump to increase pressure/volume.
Search the General section threads for homebrew solutions people have used.
Jay
<font color="yellow">
You should probably think about a bigger resivoir as well, since turning to full lock, where the ram is full pf power steering fluid, would probably come close to running the little Yota pump dry.
I called MileMarker when I was looking for a winch, and asked them about one for a Toyota. Their answer was that the Toy pump puts out 12-1500 PSI, and most american trucks run much closer to 2000 psi, so the winch would have a much lower max capacity. Just a little tidbit for you.
Also, I would definitely be in the market for a power steering cooler if I were you...</font>
toy pump is aprox 800-900 psi
stock chevy aprox 1000-1100 psi
modifeyd Howe pump is 1300-1600 psi
the volume is also increaded but i don't recall the exact numbers.
all-pro can sell you the modified pumps.
You could try running a Subaru XT6 pump... electric and variable, mount it on the fenderwell. Unfortunately I have no pressure specs yet. I paid $20 and plan to use it with a Milemarker.
Brian
1 - 8 of 8 Posts
