Hopefully my firewall will be adequate. I guess I will get some type of hood built.yes you will need a hood also a full firewall or cover the sides of the engine
If your firewall goes all the way across and is lexan or sheet metal you will be fine. if your firewall does not cover from bar to bar you will need to cover the sides of the engine up to the radiator and the back of the engine needs to be metalHopefully my firewall will be adequate. I guess I will get some type of hood built.
