1 - 5 of 5 Posts
My kid hooked up the battery backwards on his 94 nissan quest van and tried to start it. now it's dead. Anyone know which fuse i gotta replace or check??
this could be as simple as a high amp fuse being blown to total electrical failure. I would check the main fuse box under the hood it is the one that has high amp fuses in it.. It may have just blown one but be prepared for the worst
ya, check the fusible links under the hood. they will be a dealer-only replacement. if you're lucky, you only blew the spade fuse in the fusebox in the cabin. check circuits like IGN, CU, PCM, BATT+, or hell, just check all of them!
the car (or van) is protected from incidents like this, so it just comes down to finding the fuse that blew. :)
1 - 5 of 5 Posts
