1 - 17 of 17 Posts
I was under the impression that engines like the LS4 were not equipped with the provision to mount a starter to the block.
It is probably not impossible to overcome, but there is a reason why those engines are not desirable.
What does a stripped out 5.3 cost from someone like LKQ...$400? They made about 8 zillion of them. Probably cheaper to just get the correct motor rather than adapt what you've got. I am no expert in the matter, just know they are abundant.
Discussion Starter · #13 ·
Agreed. However, I'm helping out a friend. Maybe my help needs to be insisting that he part with this engine and get a different one. Sometimes a good deal overpowers good logic.
Its the 60* pattern and has not provision for a starter on the block. One could make a adapter plate and possibly mount a starter on it different from the one linked.
Google picture
If you ran a 60* 700r4 you would need to mount the TV cable on the DBW pedal it self so that's the easiest option. But still need to fab a starter mount.
Then the front drive is different as well the snout of the front of the crank is shorter. I have heard or people running a truck balance on it with no problems though.
Discussion Starter · #16 ·
I found some time to read up on this some last night.
This looks like a nice kit. More than he paid for the whole engine, though.
GM 3800 V6 Adapter Kit to Chev V8 Rearwheel Drive Trans | eBay
Sounds like you have to stick with the starter for that engine, due to the number of teeth on the flywheel. And it has a different bolt pattern so a "normal" flywheel won't work.
There are lots of custom mounts for the starters out there, some much more ghetto fab than others. Most of them mount to the transmission. That's going to be a bit of a challenge.
1 - 17 of 17 Posts
