1 - 20 of 30 Posts
What is available for my 1.6 8v motor?
I already have a Thorley header, but any advice on---
Cams
Ignition
ECM upgrades
Its not down on power or anything, and with 4.1 t-case gears, 5.29s in the Toy diffs, it turned my 35's just fine. I am just considering some upgrades and havent seen much.
Thanks
Rob
My advice is to talk to Gary at Petroworks. Email or call. He's the man!
There are a few CAMs
ported intake
Weber Carb,,,there are others but Im pretty sure webbers make the most HP
Underdrive pully
Ajustable cam sprocket
put a K&N air filter on it
Exaust
Port match the block
Centerforce II clutch
Iv never been big on ignition upgrages so I could say anything about that. Iv got all that on my 1.6 8v and the thing fruckin RIPS. Its probably putting out a good 120HP Going from stock carb to weber was almost the same difference in power as going from a solid running 1.3 to a 1.6
I had that engine in my soft top with 5:14 T-case gearing and 33's swampers and I had it up to 77mph at like 5-5,000 grand GPS verified (dash said 55)
I'm confused. My 8V is fuel injected. Do you mean going from TBI to a Weber?
i now offer 4 side drafts for 1.6 8 valve, 1.3 8 valve,and 1.6 16 valve...$495. -$575. complete ready to run... more power than fuel injection or weber ,runs upside down.......-jer
Discussion Starter · #10 ·
Got pics???
Rob
BTW- I have a header, decent exhaust (2" flowmaster), a center force II clutch, Free flow air filter.
Can the computer be tuned on these??
Rob
computer?
Got pics???
Rob
Rob
you wont need a computer [unplug],i'll post pics on tuesday... 805-746-4468-jeremy
Discussion Starter · #12 ·
I visted your website and saw the pics.....contemplating now....
Will the carbs all be tuned when I get them from u or will I have to mess when them when its all hooked up.
BTW-the ecm comment was for my EFI system that is on it now....
Rob
I am interested in a 4 carb set up for a 16v, I have a single carb set up on mine (SU HIF 44) but need more power, what sort of figures will your setup put out. I have a DT manifold & 2" freeflow exhaust, over the winter I am planning on some mild porting & maybe a cam change if I can get hold of one.
Tim
Tim
im expecting output on these motors to be at least 25-30 hp more with your exhaust than stock.... our intakes have no bends or turns i'll have pics on tuesday...- jeremy
Rob
when you get the complete set from me it is completly ready to run... jeremy i'll have pics on tuesday
1 - 20 of 30 Posts
