Out of curiosity more than anything, I was wondering how 60 FF spindles are attached to the housing?
It looks to me like the tubes are turned down and the spindles are pressed over the tube.
I stuck my tape measure down the spindle, and the lip where it expands to the ID of the tube is not where I ground the weld, but right where that fine line is an inch to the left of the grinding......so there doesn't seem to be anything pressed into the tube past that point.
If the spindles do in fact press over the tube, sure seems like the tube would be turned down awefully thin
