I built my own ramped hanger for my chevies. I didn't want as much lift as you though. I'm going for the low and wide type of rig. I'd rather trim a little sheet metal and be more stable than be high and tippsy,my truck that is. I've got a patent on this hanger and will trade a Marlin dual case adapter for the patent.85toyboy said:Lift is the issue I'm running into also, I want to run chevys but need approx 6-7 inches to run my 38's... I really don't want to run a block either. I'm considering using a ramped drop mount in the front in order to get another inch or so.
