I've got RC D60 front axles from a 78 and 85 1 ton truck. What I would like to do is able able to run 15 inch rims and to use 35 spline 1.5" outer axles. Do you know how
hard it would be to retrofit a GM/Dodge 35 spline outers? Also, what disk brake/rotor combo should I select to clear the 15 inch rims? I'm wanting to re-tube and move the pumpkin to the passenger side to put under
an FJ40.
Thanks in advance,
Charles
an FJ40.
Thanks in advance,
Charles
