Waht is the easiest way to get the spring perches off and pivot the angle up a few degrees???
Can I get new spring pads???
87 XJ
87 XJ
rotating the axle up to improve drive line angles will change posative caster to negative caster not a good idea if it is driven on a freeway . o.k. on a trail rig only.......psychochicken said:Waht is the easiest way to get the spring perches off and pivot the angle up a few degrees???
7 XJ
If we're talking about a front axle, then the advice to cut off the spring pads and weld on new ones doesn't apply...stainless steal dave said:rotating the axle up to improve drive line angles will change posative caster to negative caster not a good idea if it is driven on a freeway . o.k. on a trail rig only.......
Where in WA? I am near Yakima.psychochicken said:
anyone in WA wanna help??? $$$$
