1 - 13 of 13 Posts
Get some ribs in a flat sheet of sheetmetal without a roller?
The heat shield above the big muffler on the Disco is missing, and as long as I have the exhaust off I figger I should stick a piece of mtal in there for some heat shielding.
Oh, its waaaaaay easier to r/r the transfer case with at least the front exhaust off :)
Revor (KAK) - thanks for the advice on the locating dowel!
It was miss on my RR. I made a heat sheild that looks like this \_________/ and ran length it of the muffler It mounted to the top of the muffler where the old heat sheld was You could bend it with cresent wrench, or a hammer a 2x4's.
-Jeff
Keith Armstrong said:
Sheesh, I had just thought about KC's cave man method at lunch and now PT wants me to go buy more tools! :)
The 2X4 method works OK. I am betting he has a 2X4 on hand somewhere. Or you could wait two weeks for the HF stuff to show up, spend 3 hours assembling it due to engrish instructions, and then break it on the first try because it's from Yongkang Beshan Industrial Copy of a Russian Copy of an American Tool and Die Co. Ltd.
You're an engineer, right? :flipoff2:
Like you need an excuse to go buy another tool :flipoff2:
I'm pleased with my HF bead roller, it works great when patching rust holes in Range Rover floors!
I build stuff
Place the sheet matel on a peice of rubber mud flap, ontop of a peice of plywood. Cut the metal larger then needed and screw it down to the wood, through the rubber.
Mount a bare steel rim onto the Rover. Lower vehicle down onto metal where you want bead, drive forward.
Depending on how wide a piece of metal you are using you can either have a pair of equally spaced beads, or one bead x inches in from the edge. X= rim with -1" roughly.
I know that some folks will read this and think I am nuts, but it really will work.
Pete
Pete
And KC says I'M a hack :flipoff2:
1 - 13 of 13 Posts
