1 - 10 of 10 Posts
Well I was idling my 76 FJ-40 today and when I looked into the valve cover it looked "dry/clean" I could see oil in there on the bottom but it made me nervous. The oil stick reads "F" and the temp gage is normal.
And do the 76 FJ-40's have a "knocking "sound to them? I adjusted the valves and there fine, It seams to be coming from the block, I think it was always there but now I’m paranoid.
Thanks for your help,
TimCA
No oil pressure would be a sure sign, but the engine wouldn't last long. What is your oil pressure? If you are not sure about the gauge, get a mechanical one. 2Fs can make a little rod knock on startup when the oil pressure is low, but is should go away when you have pressure.
The oil gage (I thought it was oil temp) runs just below 1/2. I can't here the "knocking" from inside the vehical, just if the hood is up and I'm standing there. What are your thoughts?
Thanks <IMG SRC="smilies/biggrin.gif" border="0"> <IMG SRC="smilies/confused.gif" border="0">
if you didnt have to trim the head gasket to put the water pump on ,then the head gasket was installed correct.2f's do not normally make a knocking noise.How many miles on the engine? You can have good oil pressure and still have a rod knock.As far as looking in the filler cap to see if there is oil,most of the oil runs towards the back of the engine.Try using a steathascope and isolate the location of the noise
Discussion Starter · #10 ·
JSH, the majorty of the noise is coming from the block, the part with the thin sheet medil with the x on it, below the valves. I did not have to trim anything but lookin at an extra gasket it looks to me that eather its on right or not. Now I'm realy confused... <IMG SRC="smilies/confused.gif" border="0"> <IMG SRC="smilies/confused.gif" border="0">
1 - 10 of 10 Posts
