1 - 3 of 3 Posts
I'm running All Pros FJ80 hysteer kit and I have a major clearance problem between the tie rod and the pitman arm.
I moved the axle forward 3" and only run 3.5" of lift. The steering box is as far forward as I can get it without cutting into the body mount. It's tilted up as far as a could get it with All Pros upper weld on mount.
Is my only option to cut into the body mount and move the box further forward? I could tilt it up more but on full stuff there would still be interferance.
I know some of you have your axle at least 3" forward, what did you do?
I had cut into the mount on mine - but I ran a saginaw scout box now and the arm swings the other direction so the box actually sits where your shock mount is now <IMG SRC="smilies/smile.gif" border="0">
1 - 3 of 3 Posts
