1 - 2 of 2 Posts
how often should i cnage my trans. fluid, and diff. fluid, and transfer case fluid? Also should i use 90 w gear lube for all of them? I heard there was an aditive for limited slip, wich i have in rear, is this true? Thanx for the info. <IMG SRC="smilies/massey.gif" border="0">
Your gear oil should be good for quite awhile Im not sure on how long but I would think once a year would be good might even be to much,Unless you take your truck through some water crossings change the oil right after that. Yes you want to use 90wt. in all of them and yes there is an lsd oil you want to use in your rear
1 - 2 of 2 Posts
