I am dropping a 4.7L Stroker (258cui crank, .06 overbore) into my Eagle and I am debating on how to run the engine. I got the 4.0 as a core and rebuilt it (my first rebuild, might explode), but I didn't get any of the Chrysler EFI parts. No intake, throttle body, fuel rail, nothing. This was fine at the time as I was going to run a carb with the 258 intake. But I am interested in the EFI kits available out there. I do have the the money so that is not an issue.
I basically have a few options
Run the 258 Intake and a Carb.
Run the 258 Intake and a FiTech EFI
Run the 258 Intake and the Jeep Sniper EFI kit
Track down all the parts for the OEM EFI system
What would be the better option? Carb would be the cheapest and simplest, and the Sniper Kit is the most expensive. Also I need to do a Fuel pump circuit, which the EFI kits have stock. The car is a pavement princess. Using a Microsquirt would likely be a good idea instead of the early 90s computer if I get the Chrysler parts, but I'd be able to run the HO intake. I also live in a colder area, so cold starts will be an issue, but I installed a block heater due to the fact we get those arctic blasts almost every year and it can dip to -50 Freedom Units with the windchill.
I'm trying not to make a stupid decision, that's why I cant decide.
