1 - 7 of 7 Posts
Hi all, got an '84 GMC C&C dually with a narrow 14 bolt in the rear. Is there any way (with bolt-ons) to achieve a 72" DRW WMS? It is currently 63.5" DRW WMS, 40.5" spring perch spacing. My goal is to slap a dually bed on the truck instead of the dump. Thank you.
Sell and buy a Chevy dually D70. 73"WMS I do believe.
Discussion Starter #6
Thank you all for the replies. I believe spacers are illegal in my state and won't pass inspection. I think I'll go for the D70, seems like a direct swap, perches and all.
My 84 K30 dually came stock with one. It's a beast.Bigger tubes then the 14bolt though. 4". So you will need ubolts. Stock are square and bolt on the bottom. I bought normal ones from ORD and made the spring plates out of 3/8" steel. I did cut the bump stops off since they don't come close to the axle with the 4" lift on anyways. They hit the plate.
1 - 7 of 7 Posts
