1 - 9 of 9 Posts
I want to have a bit more power in my sami, it has a 2" suspention lift and 31" tires on 15X8" rims, what would i do to gain power, would a stock exhost give more power than the duel 2" exhost that was on it when i bought it a couple of weeks ago??? any type of spark plugs??? or just new ones?
i don't want to spend too much money into it by getting a 1.6L or anything like that.
thanks for your help,
l8r <IMG SRC="smilies/roxy.gif" border="0">
Here's a simple and cheap intake tube.......
http://www.pirate4x4.com/ubb/uploads/airfilter.jpg
$3 PVC T-fitting,the stock intake boots,and a K&N tube filter. It picks up the power a little and makes the cool intake sucking sound when you stand on it
assuming that the engine is basically pooched already... low compression n'all it sounds like it's time for a TURBO on that thing!...... weld up a simple log-style header and get a turbo off of a chevy sprint and you're off to the races..... literally <IMG SRC="smilies/biggrin.gif" border="0">
Assuming that your engine is tuned and all your equipment is in good repair here are a couple of cheap ideas. An ACCEL coil. It will give you a cleaner spark the the factory coil. K&N air filter it will work well with the 2 in pipe you have on your engine. Also check out IZOOK.com for info on how the mod yuor factory carb for a smoother run. Good luck and fun running. <IMG SRC="smilies/shy.gif" border="0">
Well first of all my sami has a dodge colt carb........not much more power but not any less eather...... will the duel 2" exhost be better than the stock??? do k&n filters really give more power?
Discussion Starter · #9 ·
not sure, it was on it when i bought it a couple of weeks ago, it might be custom made though......... looks the same as the one on my other samurai, except for the bottom.....:^)
l8r:
-Mike
1 - 9 of 9 Posts
