1 - 20 of 93 Posts
I didn't do this and can take zero credit. This is a fall/winter project of my long time and very good friend Frank. I let him get just about finished before I put this post up, so I wouldn't forget to update it.
The idea was to build a light weight (lbs and $$) bumper pull camper for his brother (Chris). The tow rig is an older nissan pathfinder, and the new lightweight campers are complete budget busters.
The full gallery of pics is here.. Currently there are a few shy of 1000 pics, so make sure you have a good connection and a cold beer.
Edit: pics are mostly in chronological order
First the organ donor. It took a long time to find a big enough pop-up that had a decent set of appliances for the project. I believe it took close to a year before they found actually got one.
Disassembly
Discussion Starter · #2 ·
Frame stripped.
Lifted the trailer a bit to allow a bigger wheel / tire combo.
We also boxed the frame and did some minor gusseting to take the extra weight.
Propane lines
Decking
Underside of decking, sealed and insulated.
Wall Framing starts.
Walls mocked up with doors and windows.
Installing the panel to the inside of the wall. (that's chris)
Floor tile
Progress..
Time for the roof. The best way we could figure to cut the bows was to use a straight router on jig. Frank made the jig out of scrap mdf.
A little sanding
installed.
Between Philly and Indania we couldn't find white paneling for the celing, Chris decided to use the same as on the walls.
From above
Shower Mockup
Bath walls
Add the skin
installed
The Owner checking out his new throne
The dirty work - Frank had to special order these..
x markes the spot.
Shower drain
Discussion Starter · #9 ·
Kitchen cabinet frames.
uppers go here~ish
Bathroom sink base.
Wiring
The mechanical cabinet
Discussion Starter · #10 ·
Furnace and Battery mgmt
Upper Kitchen cabinet frames set.
From under
end cap
Fridge installed
Discussion Starter · #11 ·
Tunes and Tube go here
Framing the couch bed thing
Super High tech sliding system... :flipoff2:
from the door.
Discussion Starter · #12 ·
Shot of the kitchen from the door.
Cook top and Sink mock up
Building the Counter tops
installed
Bath
Discussion Starter · #17 ·
Siding the front. I wasn't there for this (or most of it) but I understand it was a real PITA
Cutting doors and windows.
Wheel wells
Installed the door.
Lights and corner molding.
Discussion Starter · #20 ·
Shot of the roof.
Windows and front corner molding.
Propane working.
Finishing up the grey / black water plumbing
Shower surround installed
1 - 20 of 93 Posts
