1 - 12 of 12 Posts
I just picked up an SM465 with either a Dana 18 or 20 behind it (although it could be another kind of Dana for all I know). Obviously it says Dana on it. Then it has this weird sort of bridge/arm that the shifter is on, shaped like an L with Hi/Lo shifter moving the two shift rods. So is there a give away to tell what kind it is?
Thanks
Team *******
A D20 has the front output offset to the right and the rear output in the center.
A D18 has the both the front and rear outputs offset to the right.
If it is a stock GM setup, it has to be a Dana 20 - they never used a Dana 18. Dana 20s were used in some Blazers and Jimmys from '69 through about '73 or so. They could be found behind SM465s, three speeds, and TH350s.
Thanks for all the info. It's a 20 based on what TLR wrote. I was kinda wondering what it was out of, hopefully that will simplify identifying what seal I need for it.
Oh yeah, if it's a GM 20 it's gonna have a 2:1 low range. I think some of the other ones had a lower ratio (Scout or Bronco?).
Originally posted by Black Dog:
<STRONG>If it is a stock GM setup, it has to be a Dana 20 - they never used a Dana 18. Dana 20s were used in some Blazers and Jimmys from '69 through about '73 or so. They could be found behind SM465s, three speeds, and TH350s.</STRONG>
I've never seen a GM Dana 20. Are they the same as the Jeep/Scout Dana 20? Do they have the "Texas" bolt pattern on their mounting surfaces?
They are not too common, as they were used in Blazer/Jimmy only. Never compared one to a Jeep or Scout model, but I think the mounting pattern has that odd shape. I pitched the 3 speed tranny and the Dana 20 I pulled out of my Blazer in the junk yard - none of the Chevy guys want that stuff.
Discussion Starter · #10 ·
Originally posted by Grandpa_Jeep:
<STRONG>Do they have the "Texas" bolt pattern on their mounting surfaces?</STRONG>
It looks to have the same pattern. Except the shift mounter is weird as crap.
Discussion Starter · #12 ·
Originally posted by lt303scoutin:
<STRONG>scout Dana 20 is 2.0:1
Early Bronco is 2.46:1
or like me you can have a Scout D20 modified with EB gears for 2.46:1 in a scout</STRONG>
I was definetly thinking of going that route as soon as I find a cheap Bronco Dana 20. Any tips?
1 - 12 of 12 Posts
