1 - 6 of 6 Posts
98 Durango
There's a chirping noise coming from the front driveshaft somewhere near the transfercase. There isn't any chirping sound when I jacked up the rear and spun the back tires. Does this sound like a bad joint, or driveshaft?
Also, is it safe to drive the vehicle when it's making this noise? I won't be able to take it to the driveline shop till Monday.
I just changed the universal joint on my 85 4runner and before it went it was screeching like a baby. I still drove it around for about two weeks before I changed it though. Those needle bearings were toast. The squeeking is most likely a lack of lubrication and alot of rust (as mine were).
It is very likely your U-Joint.
Nick
Almost always you get a vibration before the chirping.
The chirping is your needle bearings turning to dust.
Grease wont help now.
If you can't feel slack in the u-joints by hand (in nuetral wheels scotched)
Take one end of the shaft loose.
and move each u-joint back and forth.
If it's hard to move in one direction, that's the joint with the problem.
BTW I had a vibration in mine for the last week, just didn't know which joint was bad. I pulled 2wd drive chevy up the hill yesterday in the snow. When I turned around you could hear it chirping. So last night I pulled the rear shaft and my upper was bad.
1 - 6 of 6 Posts
