Gentleman,
Long time reader, first time poster (as far as posting for a question)
Heres my situation, im trying to get this hp 44 (dynatrac built in 2001) into the front end of my xj. specs are as follows
standard width
4 link (running tnt customs radius arms)
stock wheelbase + 3/4" movement of springs so steering would clear
wj knuckle swap (with euro knuckle, and OTK flip) 2 hi arms, with inverted t one ton steering.
1/4" spacers obviously with 2001 timken hubs.
arb. gears chromies, blah blah blah.....
so, the previous owner thrashed the right side brackets. to include tearing off the track bar mount and the front of the coil bucket on his mj
I purchased the axle, along with a ballistic fab tj/xj combo bracket setup and ruff stuff panhard kit.
Im trying to set the pinion angle appropriatly however from a few differnt threads and multiple searches i am getting conflicting information.
another person who built a hp 44 for an xj at 6" of lift set their pinion angle to 13 degrees.
while someone else said for around that height with 6" the pinion should be around 7 degrees.
i was running a lp 30 before, (stock 2000 xj) and at 5" on 35's i wasn't having any issues. But i was also running utk steering and track bar.
here are the threads i had been using for reference.
Bolt In High Pinion Dana 44 - JeepForum.com
and Dana 44 Tech - NAXJA Forums -::- North American XJ Association
im not asking for a miracle answer, just hoping someone else that has already done this might have some insight. i will attach pictures of the axle, and show where i am taking my measuments from.
Previous owners damage to axle brackets.
axle with pinion set at 13 degrees, with coil bucket resting at 0.0
Is it just me or does the pinion angle look ridiculously high?
again, i havent put it under the vehicle yet.
Go easy guys, this is my first time posting here and i know how the questions threads usually go. First time doing a non bolt in axle swap.
standard width
