1 - 20 of 26 Posts
I have a HP d 44 that is missing from the spindle out. Everything else is there (housing, 3.54(?) gears, carrier, inners and outers, caliper brackets, etc.) I do have the stock spindles but they are a little beat. I just picked this up but changed my mind and am thinking another direction. I'm asking $150 OBO and I'm in Fresno. And this is the housing that the Cs can be easily cut off.
Not sure what the WMS is since it was missing rotors when I got it. I believe it is from a F-250 since I've heard that only the F-250's had the welded on C brackets. It is a Driver drop. It was from a Ford and was coil sprung. Again the C brackets are of the type that can be cut off easily! My assumption is '78 or '79 Ford pickup.
part it?
F-250's were leaf sprung. '78-'79 Full-size Bronco's had cast-in brackets...so what you've got it most probably from a '78 or '79 F150. If you're interested in parting it out, I could sure use just one of the spindles.
What is it ?
Have you decided what you have ?
78-79 will have cast outers with integrated "C's", whichare not desirable for swaping into any vehicle that does not use the c-bushings.
77 and earlier housings use steel tubes with the "C" brackets welded on to the tube. 76-77 axles will have disks.
Do you have a 76-77 or a 78-79 ?
F250's will be leaf sprung and low pinion...
If it is a 77 or earlier, I have a buyer that will pick up.
Let me know...
kris.
Discussion Starter · #17 ·
Not positive on year as I don't do Ford stuff. It has the "Cs" welded to the tubes, not cast. It was a disc braked axle as I have the caliper mounts that came off it. PM me if he's serious and I'll get ya my phone number.
Can you get me the Bill Of Materials number off of it? I can tell you exactly what it is from. And if you want to part it, I'll take the caliper brackets & backing plates if you still have them.
1 - 20 of 26 Posts
