1 - 3 of 3 Posts
Howdy --
I'm upgrading my drivetrain on my '97 TJ 6 cyl and trying to take the advice of the folks who say "only do it once".. :)
I'll have 35" (maybe 37's) tires initially, with a max of 39's at some point I'd imagine. With my 35's (or 37's) I plan on 4.5" of lift (RE 4.5" springs) with either RE's long arm kit, or a custom tri link. plus a 1" body/motor mount lift.
I'm thinking of getting a couple of RCD60's from 78-79 ford's, and run them full width. I'd obviously have to have the rear RC60 re tubed with the tubes from a standard D60 (any other options?).
Will I run into any clearance/binding issues with a humungous reverse cut 60, and such a (relatively) small amount of lift? (either front OR back) What about my track bars if I keep them? From what I've seen, it LOOKS lik it will work, but is there any trick to make it work?
I've used the search button :flipoff2: and come up with all sorts of juicy bits on RC60's (although I still have more questions, but those can wait until i've done more research :)) but haven't found anything about this in particular.
There is a guy I know that uses this board from time to time (anger mgmt) who is re-building-up his TJ with a HP 44 and a Dana 60 on a short lift, ~4" if I remeber correctly. He said he was kind of forced to go with the HP 44 up front over the HP60 due to clearance issues. When you throw a pig that fat under a cluttered TJ front end with a short lift there will be clearance issues. He had trouble clearing everything with highsteer and hydro assist. I guess you could make it work but you would have to either make some trackbar, oil pan, frame, ect. modifications or make some suspension/steering comprimises.
1 - 3 of 3 Posts
