1 - 8 of 8 Posts
drag link rubs on the springs on the right side in sertain situations.i cut the little clamp flush with the springs and the springs still look like they will rub is this a problum and if so what is the solution.planing to go to 4dice tomarrow can i go like this ? <IMG SRC="smilies/usa.gif" border="0"> <IMG SRC="smilies/usa.gif" border="0">
Do you arms have any lift to them? I have 44044's and trail tech hy-steer and I have a good 2" before they could even think about hitting the springs.
Originally posted by Loco:
<STRONG>Do you arms have any lift to them? I have 44044's and trail tech hy-steer and I have a good 2" before they could even think about hitting the springs.</STRONG>
thay do have a little but not that mutch thay are marlins kit.when sitting in the drive thay have about 1" for the drag link less for the ty rod
I have the Allpro Hysteer kit with 44044's on my 85 Runner. I don't know how you mounted your springs, but mine are in the stock widened mounts with 1" lift shackles. The only thing that rubbed on mine after the initial install was the 3/8" thick u bolt flip plate I made. I just cut off the front angled part and it's fine now. I don't run any bumpstops, but that may be what you need to do to keep the rod out of the springs before you can't steer.
Does yer dewg bite?
I have the same setup and mine also rubs. Shouldn't have any problem. I haven't
just got back from fordyce worked great first trip with the duel t/case and the hy steer.con't beleave the difrance.now that is wheeling. <IMG SRC="smilies/bounce2.gif" border="0"> <IMG SRC="smilies/bounce.gif" border="0"> <IMG SRC="smilies/bounce.gif" border="0"> <IMG SRC="smilies/bounce2.gif" border="0"> <IMG SRC="smilies/usa.gif" border="0">
1 - 8 of 8 Posts
