1 - 13 of 13 Posts
First off I did search for 2 hours and did not find a topic pertaining to this particular question. I am planning to build a hybrid pack. I have a set of stock rears and a set of stock YJ rears with two additional leaves to stiffen the PO's spring over. I am curious if anyone has done this setup and which leaves from each pack make for the best overall pack. I'm not looking to get tons of lift out of this setup, just a couple of inches and some killer flex. Flame if you want, but I did search extensively.
Broke Bastard
You may have thought about this already, but to you realize the 2 spring packs are different widths?
I used the rear main leaf and 2 leafs from a 3" lift pack. Along with 2" longer shackles. It gave me about 4" lift. But obviously you dont have the same springs to work with.
I wouldnt use YJs, they are to flat to begin with. But that is just a personal opinion. They may work for you...
Here is what I run on mine:
top main leaf stock 2 wd 84-88 Toyota rear
2nd mil wrap stock 2 wd 84-88 Toyota rear
3rd trimmed mil wrap leaf from 4x rear 19" from spring pin
front, 24" rear of pin
4th trimmed leaf from 4x rear 18" from spring pin front,
22" rear of pin
5th trimmed 3rd leaf from 2 wd rear 14" from spring pin
front, 19" rear of pin
6th trimmed leaf from 4x rear 8" from spring pin front,
11" rear of pin
These flex like nuts and can carry the weight of a winch or plow but still flex well. Gives about 4" of lift.
Can do the same with rear 4x leafs but will need some lift leaves from an aftermarket supplier cause they only give you about an inch of lift and NO load carrying capacity.
Just play with them, throw some leaves in, set the rig on the ground and see where it sits, then go test them and adjust. If you think there's room for improvement then take them back out again and play with more leaves. I'm about to redo my springs again, and I have a general idea of what I want, but it's just going to take some playing around.
Discussion Starter · #9 ·
Thanks for all the help so far. By the way, I just got rid of the 'Cruiser and picked up a mini so it will be on an '83. So far I am leaning towards Booger's setup because I already have all the leaves to do it and no added cost of buying aftermarket lift springs. Thanks and keep 'em coming.
overeasy said:
I run 3 toys with the bottom 3 from a 4" lift yj spring. 4-5 lift and flex great.
so does my buddie.. he has the exact same setup:eek:
yea what about that? not that big a difference or who cares bolt it together and go?
1 - 13 of 13 Posts
