1 - 20 of 23 Posts
I plan to install hydro assis steering on my YJ but I couldn't find a place to buy cheapo but powerful no frill ram steer cylinder. I think it was called Columbus cylinder.
Not gonna blow money on expensive AGR or PSC assit steer system.
Also need a website telling me precisely on where to tap the YJ steering box and where to find the hoses and fittings.
91 YJ HP D44, 8.8, 4.88, Detroit lock'd, RE Xtreme 1.5" springs, heavily armored, 37x13.5 nitto mud grappler
"Vulture" Jeep
Excellent website on where to tap the steering box but...is the 81' Wagoneer steering box the same as the 91' YJ steering box?
The information and tips that you gave me is really helpful!!
Will port and tap my YJ steering box this weekend.
Long live the Jeepers!
Vulture jeep
Cylinder and hoses and fittings for 100 bucks??? Which store? what is the brand name/model of the cylinder? Is it 8 inch ram?
that would be possibly your local tractor supply and they are chief brand cylinders.. seem to work for everyone around here. can be had for around 100 as stated earlier... and yes i think he was talking a 2x8 ram which runs around $69 at tractor supply.
Chris
Discussion Starter · #10 ·
yea, i have checked around and found that they have Lion 2500 cylinder but it is not welded cylinder, it is being held togther by long four bolts. It sells for 69 bucks. Looks chunky and awkward to me. Welded cylinder is what I am lookin for ...Ok will keep on lookin round. Thanks
Discussion Starter · #13 ·
Bingo! Welded cyclinder is what I am lookin for! Did you use any one of those on your rig? Which one is better? I am leanin' on the yellow one.
Thanks!
I
Thanks!
I used the black one with the fixed ends......worked ok........yes I would lean towards the yellow one also
BTW used a fixxed mount on the tie rod........my adjustable mount would not tighten down enough and actually would turn the tierod and change the toe in............
How do those Assist setups do on the road? Im going to be running 37's on my CJ in the future, and Im thinking about doing it, but its my DD so road manners are a factor.
got my hoses and ram from Northern Tools. ram(8x2) was $60 and the hoses were another $24 each.
Cant do better than that. Cooler was an ebay score, (trans cooler)for $8
C-
C-
So you are sunning your PS fluid through a transcooler? Is that nessicary? pros cons?
1 - 20 of 23 Posts
