1 - 20 of 661 Posts
Rock Stacker
Edit: Like most of the Pirate build threads, all the pictures were lost when PhotoBucket purged. I have gone back and uploaded directly to Pirate.
This is part two of the buggy. First off I want to thank all of you for following along and for the encouragement you have given me over the build process. Pirate has played a major part in the build process. The buggy is almost ready to hit the trails and start testing. In this thread I plan to cover the testing and report back with what I find and any changes made along the way.
115" wheelbase
84" wide
81" tall +18" adjustment
12" Belley Clearance +18"
5500 lbs 60% sprung 40% unsprung
LS 6.0
Team 208 Motorsports harness and tune
Griffin and Spal fan setup
Thermal Transfer hydraulic oil cooler and Spal fan
PSC 3" Double ended steering cylinders
Auburn planetaries
Rexroth drive motors
Sauer Sunstrand hydrostatic M46 tandem pump
Gates 6000 psi 3/4" hose
VVR hydraulic variable volume reservoir
54" x 19.5" tires Baja Claws on 20" double beadlocked rims
Top speed 30MPH
Pumps Displacement 2.81 CI/REV
Pump Max REV 4000 RPM
Pump Max PSI 5000
Planetary Ratio 30:1 Rated @ 50,000 Inch/LBS
Drive Motor Displacement 1.5-2.75 CI/REV
Hydraforce flow divider combiners with bypass circuit
PRP comp seats
Optima Yellow tops
Warn 12000
Rigid LEDs
Fox shocks 2.5" X 10"
Thomas 1HP 150 PSI air compressor, chassis air tank
Factor 55 Fairlead and Prolink
Slam Specialties 8" SS air bags
Donaldson industrial air cleaner
What was the reason the first thread went bye bye?
Awesome glad to see some updates.
that is still the most crazy sexy thing i have ever seen. cant wait to see how it does. good luck.
I didn't see the first thread but I wish I had. Could you put out the specs on the rig. You have a nice blend of simple and complicated going on :smokin:
Wayne
Needs more triangulation :flipoff2:
I never saw the original thread, so all I have are a bunch of questions....
You decided you wanted to start over, so start explaining what your design goals are.
:smokin:
man i miss the first thread, some damm fine fabricting in there. anaways how do you like the overall performance and do you have any vidio's of it.
jason.
1 - 20 of 661 Posts
