1 - 20 of 67 Posts
I wanted to get it running, and driveable today...no such luck.
It turns over, and almost starts to run, but doesn't...I think I need to get the computer diagnostic thingy...
I have spark, I have fuel, air is there...what else could it be??
Also, I tossed some 42's on this morning. They look too big to me. No uptravel. What do you guys think?
if you have to ask you are way to scared to run 42's, better step down to the 38's till your balls fall from your mouth! jiMMy
looks damn good
congrats
the 42's are awsome
just cut the fenders
i still love your cage
what about timing? You have TPI right
so maybe not
good luck
Discussion Starter · #11 ·
Brett....
It is a vortec. I am not sure if it will work, but I plan on calling the guy I bought my CRAZY wire harness from to start asking him questions. My O2 sensors are not hooked up yet, ...I don't think they would cause it not to start, but possibly run funny?
Anyway, I would like to make it to TDS on Friday. I have to get it running, and the front Brake lines replumbed.
Not sure I want to post pictures of the portals...you guys do some amazing work, and mine will look like sh!t to you guys! So if my "Balls drop" I will post some....
**********So, you guys don't think the 42's are too big for the portals???*******
OK, here is a picture with 35" tires... With the 42's, I have 18 inches of clearence to the pumpkin....
UHHHH THIS MAY BE WRONG, BUT I REALLY DONT THINK SO. ALOT OF PEOPLE TALK AS IF YOUR CENTER OF GRAVITY DOESNT GET HIGHER WHEN YOU GO TO BIGGER TIRES WITHOUT ANYMORE LIFT... UNLESS YOUR SUBSTANTIALLY WIDENING YOUR STANCE AT THE SAME TIME, LIKE GETTING NEW AXLES, OR BIG SPACERS OR SOMETHING, YOUR STILL GETTIN TIPPIER BECAUSE YOUR CENTER OF GRAVITY IS RAISED AND YOUR TRACK IS NOT WIDENED ENOUGH TO MAINTAIN THE OLDER RATIO...
JSUT THOUGHT I'D THROW THAT OUT THERE AFTER SOMEONE SAID SOMETHING LIKE "RUN THE 42'S MAN! THE LOWER THE BETTER"
Discussion Starter · #17 ·
Proffitt, would you mind PMing me your number??? I would love talk to you about this thing...
Steering column is a 86 chevy blazer with tilt. Pretty cool, but the high low beams are on the floor :(
Wheel base is 98.5 inches and 83 inches wide. I peronally don't think they are too big for the rig...I could be wrong, but I think heighth and width wise, I should be good. The question should have been "Do you think these Volvo portals will support them?"
A couple more measurements...23" to under the frame rail, 18" under the diff! And about 83" to the top of the cage.
Now what do you guys think?
I think the volvos will support them if you drive smart= not flooring it with two wheels in the air etc. I think the first thing you will break is a birfield so longfield them maybe a good idea.
Did you use the original spring preaches?
Discussion Starter · #19 ·
Tell me what longfielding them is...I have head of it, how much does it cost? How will it benefit?
I made my own perches. the tubes are flat on the drivers side, and a little round on the passengers side...hard to explain, but they are not consistant...therefore I had to fab up some myself...not a real impressive job, but it will work.
OK, answer me this...if my up-travel is limited by the 42's, wouldn't it make more sense, from a functionality standpoint to go smaller???
You bring up a good point! the rig will be more tippy witht he 42s vs the 38.5s all things being the same. I guess what I ment by "the lower the better" was the lift. Id rather see a guy take a sawzaw to the fenders for clearance than lift it till it no longer rubs
1 - 20 of 67 Posts
