1 - 17 of 17 Posts
anybody got some junk passenger side steering arms laying around? i would Perfer 76-78 cruiser pattern, but anything will do. thanks a lot!
-Max
I've got one from a '70, but shipping would probably kill the deal. :fj:
I'LL HAVE ON FOR YA SOMEWHERE BETWEEN 2 WEEKS AND A MONTH FROM NOW, IF YOU STILL NEED IT
shipping is free...if you just box it, i can get it picked up from your house. also, its a passenger side one right? i need a passenger on to make a double steering arm.
btw, thanks fixah and butch....if brandon falls thru, i will let ya know!
texican said:
I've seen welded ones break......recently in fact.
Be safe......
JT outfitters has them cheap.
Butch
thanks for the concern, but i, or my father will not be welding it. my dad's best friend owns a welding business, and well it wouldnt be a big deal for him to weld it...and weld it right ;)
Be safe......
Butch
Buying that cheap double-steering arm from JTO is not any cheaper than the infamous Aqualu arm and is just barely cheaper than SOR's hy-steer arms (which would get your tie rod up, up, and away) and the amount of $$ needed for any of those purchases is pretty much half-way to a complete hy-steer kit from all-pro offroad (and probably other places as well). There are plenty of options out there to purchase...
McGee, sorry, I don't have one for ya....just had to add my two cents...
ninetimesnine said:
...SOR's hy-steer arms (which would get your tie rod up, up, and away) and the amount of $$ needed for any of those purchases is pretty much half-way to a complete hy-steer kit from all-pro offroad ...
Sorry... these won't fit a pre-79 axle....:D
Does anyone make a hy-steer setup for the pre-79 axle yet? I know a few dudes have fabbed up their own but I need some bulk type stuff....:D I have a couple of customers wanting some...;)
Rockbuggysupply.com can supply you with pre-79 arms. There was a thread about them the other day. You even posted in it! :flipoff2: :D
http://www.pirate4x4.com/forum/showthread.php?s=&threadid=115796
rustycruiser said:
.... You even posted in it! :flipoff2: :D
Holy shit... I did....:eek:
I told you someone was making them... stop listening to what I say and start listening to what I mean...;)
I still have one from a 60 series if that will do. If you are solid on fabbing one up, if you use your stock arm for the bottom and the 60 for the top you should be fine. Check out woody's site in the links section I believe it's the All-Pro Off-Road.com link Jim B something that shows picts and directions for fabbing one up. good luck! Shipping would probably be aorund $20 I guestimate...
dieselcruiserhead said:
I still have one from a 60 ...
Dude save that for me... I ahve some drum brake shit that he can use for his home-made arm...;)
1 - 17 of 17 Posts
