correct, looks that way from the angle anyways84-85 judging by the bottom truss. Kinda hard to tell but it looks like pink on the end of pinion, 4.10 geared.
x2 or 3 or... with locking hubs you need to put on Craigs list.84-85 judging by the bottom truss. Kinda hard to tell but it looks like pink on the end of pinion, 4.10 geared.
warn hubs suckx2 or 3 or... with locking hubs you need to put on Craigs list.
Say, using 33s, 4.3, and to use for mainly trailing where 2wd may have difficulty over certain angle. Will this axle still be ok to use?They are way weaker than the stock Aisins. Worth $250 on CL around here.
Fixed.
Absolutely not! The bolt pattern on this axle won't bolt up to 33's. Plus with a 4.10 gear it will be like driving upside down. . . DUH!!!
