1 - 9 of 9 Posts
Wanting to swap in an IFS rear under my '82 Toy, is it basically bolt in or do the spring pads have to be moved in or out?
Any other info would be great, Thanks.. <IMG SRC="smilies/bounce2.gif" border="0"> <IMG SRC="smilies/bounce.gif" border="0">
Originally posted by OOPS:
<STRONG>Bolt in, make sure you get the whole thing,including brake lines and e-brake cable. <IMG SRC="smilies/usa.gif" border="0"> <IMG SRC="smilies/usa.gif" border="0"></STRONG>
Hey David, remember me? I bought your IFS front diff. a few years ago.. Works great.
It's pretty much bolt-in, I just put an '87 rear axle in my '84 a few weeks ago. The only trouble I found is that the axle tube is slightly larger in diameter, so if you want to re-use your stock u-bolts and plates, they don't provide enough room for the larger tube. I solved it by egg-shaping the holes in the u-bolts plates, and grind a slight groove in the tube.
The better option is to just do a u-bolt flip, but I couldn't do this as I don't have anything solid enough on my frame to mount the upper ends of the shocks to. <IMG SRC="smilies/frown.gif" border="0">
Wicked Raciest !
Originally posted by KLF:
<STRONG> so if you want to re-use your stock u-bolts and plates, they don't provide enough room for the larger tube. I solved it by egg-shaping the holes in the u-bolts plates, and grind a slight groove in the tube.
I don't have anything solid enough on my frame to mount the upper ends of the shocks to. <IMG SRC="smilies/frown.gif" border="0"></STRONG>
Bad Idea!!!! watch for cracks where you put the grooves!! <IMG SRC="smilies/eek.gif" border="0"> Why don't you weld a new x-piece in!! <IMG SRC="smilies/usa.gif" border="0">
Wicked Raciest !
Originally posted by LoRent Toy:
<STRONG>Hey David, remember me? I bought your IFS front diff. a few years ago.. Works great.
<IMG SRC="smilies/biggrin.gif" border="0"></STRONG>
Sort of!!!! I have CRS. Glad that it is still working for you with no problems!!!
<STRONG>Bad Idea!!!! watch for cracks where you put the grooves!! <IMG SRC="smilies/eek.gif" border="0"> Why don't you weld a new x-piece in!! <IMG SRC="smilies/usa.gif" border="0"></STRONG>
The grooves are very shallow, maybe 1/16" max, I really don't think it will cause any weakness. I can't do a new crossmember cause there's nothing left up there to weld to. My frame is toast, this is it's last winter, for sure. <IMG SRC="smilies/pissed.gif" border="0">
Spring mounts are the same parking brake from relay back is longer. I just kinda \/ kicked out my u-bolts and illiminated the bumpstop and it worked fine for years till I flipped on my new ride. Just check em alot.
before
<IMG width=376 height=584 SRC="http://www.pirate4x4.com/ubb/uploads/IFS rear 1.JPG">
after
<IMG width=376 height=584 SRC="http://www.pirate4x4.com/ubb/uploads/IFS rear 2.JPG">
If you look close at the second pic you can see the u-bolts are kicked out a little
<IMG SRC="smilies/tongue.gif" border="0">
[ 10-23-2001: Message edited by: Just make it stop Skyetone ]
1 - 9 of 9 Posts
