201 - 210 of 210 Posts
Discussion Starter #201
Took my top and put a new coat of primer on it and painted it.
3107510
3107512
Bought a new gas tank with an in tank pump and LED light bar mount from Binder Boneyard.
3107514
3107515
3107516
And bought a new np205 support from TMR
3107518
Discussion Starter #202
Out with the old...
3107520
3107521
Discussion Starter #203
Pulling out the input gear to make way for the new Black Box gear.
3107663
3107664
Getting the Black Box all mounted up
3107665
3107666
Discussion Starter #204
Took the old speedo thread portion off, cut it and drilled and tapped to for a plug.
3108831
Got the trans and tcase all bolted up together.
3108832
Took some measurements for the modifications needed on the aluminum gas tank I bought. I suspected we'd have issues with it considering my scout is far from stock.
Took it to a local shop and gave him the measurements to start cutting.
3108833
A few weeks later and it was all welded up.
3108834
Put it underneath and had to clearance the rear frame cross brace, and cut off the front gas tank strap support member.
3108835
Should have plenty of clearance for up travel now. I figured I lost about 1 gallon of capacity. Not too terrible.
3108836
Discussion Starter #205 (Edited)
We finally got the trans and tcase back up under the Scout. Upgraded the 4 link joints aswell.
3109228
Speaking of upgrades.... Decided to bite the bullet
3109229
Discussion Starter #206
SHES IN!!!
3109278
3109279
3109280
3109281
Discussion Starter #207
More work getting done between life events... hoping to have it all "done" by next spring. Engine installed, coil overs in rear, tire carrier, new center console and all wired, done!🤞
Cycling the front suspension up and down to check for clearance and full bump with the oil pain and 4-links. Going to have to make some slight adjustments with the top axle links.
Got the new gas tank all wired and plumbed to the corvette fuel regulator and installed.
3111260
3111261
3111262
Discussion Starter #209
Thank you!
We got some more work done on the front end this weekend.
Swapped out the OEM dana 60 inner shafts for some chromoly shafts and installed the CTM u-joints.
Cycled through the front suspension and relocated the top mounts to clear at full bump.
3111425
3111426
3111427
3111428
3111429
Discussion Starter #210
Scouttanks and I were able to mock up the front end with full bump and full droop after moving the top link mounts to clear the oil pan of the 6.0l. Got the bump stops in place and welded up.
3111595
3111596
3111597
3111599
3111601
3111602
3111603
Placed the radiator and fan in real quick just to see if I had any clearance issues.... nope!!
3111604
