1 - 8 of 8 Posts
I hope that one of you has a solution to my problem and that is when my 88 samurai (bone stock under the hood) is running with the clutch pedal out everything electrical is extremely weak but when the pedal is depressed it seems like everything is fine, any advice greatly appreciated!!!
Is there a noticeable difference in RPMs from when the clutch pedal is out to being pressed?
Discussion Starter #6
Just looked for both grounds wires from frame to body and from motor to frame and can't find them where are they normally located?
Discussion Starter #8
Thank you guys for your help threw a couple of new grounds on and everything is now working properly!
1 - 8 of 8 Posts
