Our latest addition to the product lineup! This kit replaces the factory cast adapter and allows you to clock your tcase in ANY orientation desired. Recoup some coin by selling your old adapter. :smokin: Full spline engagement is maintained, unlike clocking plates that bolt between the factory adapter and t-case. Simply weld the components together in the orientation preferred. Hardware is included. Additionally, a mounting plate is included for you to use when building your cross member (We typically would use tubing with bushings mounted at the chassis but that's up to you). Shown below is a TH-400 to figure 8 205. Accepts factory seals(not provided). We can produce all of the popular GM combos. Custom/non GM configurations are possible with some additional input. Contact us with any questions or needs. We can help you work through any shift linkage if needed as well. The adapter shown below is $325 shipped to your door. Contact us for alternate configurations and pricing.
Thanks,
Mike
Trail Tech Fab
Clocked Up
Clocked Down
See page 2 for some more pics of TH350/700R 2wd trans setup.
Add a NP 205 rear support/torque mount for $60 now when combined with a clocking plate or Infinitely Clockable Adapter kit!
More info on the 205 mount can be found here.
http://www.pirate4x4.com/forum/showthread.php?t=1014481
Thanks,
Mike
Trail Tech Fab
Clocked Up
Clocked Down
